Tire warning light won't go off
all the tires have enough air in them but the warning light won't go off. anyone have this problem before?
ive got the same problem... the TPMS needs rebuild kits. Should set you back like $40.
One of them may have gone bad or they just might need a reset.
The rebuild kit will not make the light go off. It just replaces the rubber seal, aluminum nut, valve core, and valve cap. Also, they are more like $2 each, not $40. |
appreciate the info
reset them and go from there....if that doesnt work replace them (hope u can buy them all cheap)
| All times are GMT -4. The time now is 08:48 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
