G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V35 2003-06 (https://g35driver.com/forums/g35-sedan-v35-2003-06-15/)
-   -   Service Engine Light came on...don't understand light flash pattern? (https://g35driver.com/forums/g35-sedan-v35-2003-06/352193-service-engine-light-came-dont-understand-light-flash-pattern.html)
sergio3986 Sep 27, 2010 08:39 AM
I chekd my service engine light, manually...and I don't understand this light pattern, there for can't look it up to determine why the service engine light triggered..
I get the following light pattern: 10 slow flashes, 4 fast flashes, then 5 fast flashes and then another 5 fast flashes...and then it just starts all over again
Any ideas what code that is???
I have searched all over the forum with no luck. I seem to remember beign able to find SES how to and ocde lookup easier on here in the past
Metalp3n Sep 27, 2010 08:48 AM
I wish I remembered what exactly the 10 slow blinks meant. It was either for 0 or for 1. The remainder equal to 455, as the ending to your CEL code. It seems to be the code it is popping up is 0455, or your EVAP System.
I did a quick search and found this thread for that code, hope it helps:
https://g35driver.com/forums/engine-...uble-code.html
Mustang5L5 Sep 27, 2010 12:49 PM
0455..more than likely gas cap.
Drive to Autozone, and borrow their code reader. Erase the code, and then drive for a few days and see if it comes back.
There are other causes, but most frequently it's from not clicking the gas cap all the way. Had it happen to me. Why i suggest trying the easiest fix first and just do a simple reset.
sergio3986 Sep 28, 2010 08:31 AM
Awesome thanks!!!! Much appreciated
Bestswat Sep 28, 2010 10:08 AM
Most likely gas cap, or engine misfire(but this you can tell)
© 2026 MH Sub I, LLC dba Internet Brands
