G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V35 2003-06 (https://g35driver.com/forums/g35-sedan-v35-2003-06-15/)
-   -   Gas Pump Door Doesn't Lock (https://g35driver.com/forums/g35-sedan-v35-2003-06/353020-gas-pump-door-doesnt-lock.html)
nabeelf Oct 4, 2010 08:54 PM
hey guys, so i just noticed that my gas pump door doesnt lock when i lock all doors by either the remote or the key.
not sure whats the problem. Can anyone help me out?
Whats broken? What parts do i need? How to fix?
thanks
nazc0 Oct 4, 2010 08:59 PM
might be a broken actuator but be glad its not stuck in the closed position
kevink Oct 4, 2010 08:59 PM
There is a cylindoid that locks/unlocks it. Should be glad it failed in the unlocked state :) A few months ago I went to buy gas and it didn't open. Luckily, it wasn't an emergency, and since I was in the town with the dealership, I went in and they removed it. Then, when I was in town the next time I had it replaced.
It is mostly labor which drove up the cost. Had to remove the trunk lining to get to it.
bryman10 Oct 5, 2010 07:10 AM
.....like mine was the other day. I had to pry it open (and thus bend it all to hell in the process) with a screwdriver.:mad:
bryman<-----luckily found one on ebay (for $50...yikes!)
vp-g Oct 5, 2010 07:47 AM
mine never locks i thought thats how it was?
WILLIE BEANS Oct 5, 2010 11:42 AM
i was in that situation too .
but mines got locked . and couldnt open with door locks .
so i opened the trunk removed the lining behind the gas door and felt around ..
i found that theres a stick you can push and pull thats actually what locks your gas door .. i pulled it and gas door opened ..
after gassing up i pushed it in . and gas door locks . lol
i bought a gas cap with a lock on it for 5 bucks . until i get a new actuator ..
coolieman1220 Oct 5, 2010 11:53 PM
its very easy to fix!
just rip off some interior panels and its there. i've lubed mine, disconnected, all sorts of stuff and it worked on and off. eventually i got fed up being locked in the lock position and i tied a string to it, ran it to the trunk and if i had the problem of it stuck locked, open the trunk, pull and it opened!
SEARCH BTW!
© 2026 MH Sub I, LLC dba Internet Brands
