ignition not starting smoothly??
So ive had my G for a month now and ive noticed since i bought it that every once in a while when I go to start it, it kinda stutters before the engine really kicks in. Its doing this about 30% of the time and im not to sure what it is. Do you think it just needs new spark plugs? the car only has 43k on it if that helps.
Marvel's Mystery Oil in the fuel system for a few tanks of gas.
So a few cycles of that in my gas should help? ill give it try, thanks
try cleaning your MAF sensor or throttle body. Whats your rpm at when you start your engine? if it's idling really low, your ECU may need to re-learn the throttle position.
Marvel Mystery Oil is awesome!
But it may not cure your issue. It will clean out everything. |
