First Gen (03-06) G35 Sedan Tips/Tricks/Facts You May Not Know
Old 05-07-2012, 07:45 PM
NFSP G35's Avatar
? = 2B || !2B
^Um... physics says no.
IR is a beam of light coming out the front of the remote. If you point that at your head, you're just going to block the signal.
  #47
Old 05-07-2012, 11:02 PM
2005Garrett35's Avatar
Yea, that makes sense. My mistake
  #48
Old 05-08-2012, 03:33 AM
drifterxG's Avatar
Not sure if this was mentioned. If you have a keyless button under rear-left tail light (05-06), you can only press it if all 4 doors are unlocked. Otherwise, it won't work if just the driver's door is unlocked.
  #49
Old 05-08-2012, 07:38 AM
NFSP G35's Avatar
? = 2B || !2B
^Ah good point. I forgot about that.
If I'm not mistaken, the same applies to the "doggy door"
  #50
Old 05-08-2012, 09:15 AM
Bastone's Avatar
I have the Kelyess Trunk release button under my driver's side tailight, and I can use it to open my trunk even when all the doors are locked, or only the driver's door is unlocked.
Works everytime.
WhipWhitaker (05-11-2012)
  #51
Old 05-08-2012, 10:33 AM
drifterxG's Avatar
Works everytime.
Then you tricked your own G to thinking it's allllll good
  #52
Old 05-08-2012, 10:38 AM
drifterxG's Avatar
I just picked one of these up yesterday: http://www.ebay.com/itm/280790550909...ht_4520wt_1165
Only thing I'm wondering is, how am I going to move the little chip that's in my key into this remote? Anyone know more about our keys? Might have to take it to Infiniti if no one knows how I can use this remote.
MPG35fiend (05-16-2012)
  #53
Old 05-10-2012, 10:10 PM
ibg's Avatar
ibg
ibg is offline
If you found the solution for this please post it cause i want to buy one of these as well
  #54
Old 05-11-2012, 09:23 AM
Bastone's Avatar
Enjoy!
All the info you need is in here.
Upgrade your ugly FOB to a nicer Infiniti SmartKey
  #55
Old 05-11-2012, 12:03 PM
drifterxG's Avatar
Enjoy!
Thanks for the tip #Bastone. I've seen this type of tutorial on the forum, but still looking for a way to use this key fob as an 'all-in-one' key. Our keys (03-06) have chips in them. I'm heading to Infiniti to ask how to slip out the chip from the key, because I can see there's a small rectangle opening near the bottom of the key handle.
  #56
Old 05-13-2012, 02:04 PM
RADRaze2KX's Avatar
I've owned my '04 Sedan for 4 years and discovered two weeks ago the jack tucked inside the trunk on the left-hand side behind the pull-away panel... mine was barely sticking out, so I didn't know it was there and purchased a new 2-ton jack... to pull out my OEM jack, I had to "compress" the jack by twisting the thing that expands/contracts the jack...
VQ_MAC (09-24-2023)
  #57
Old 05-13-2012, 03:33 PM
Hotdawwgman's Avatar
nice! LOL
  #58
Old 05-15-2012, 11:06 AM
drifterxG's Avatar
Anyone know some stock Valet features using the 'valet' key that came with the car? I think it limits the speed...
  #59
Old 05-16-2012, 11:44 AM
g35_white's Avatar
Did 2005 G35 premium package came with one touch sunroof open and close? Mine doesn't do that. I have to keep it pressed in order to open or close.
  #60
Old 05-16-2012, 12:16 PM
Swivel's Avatar
Moderator
^ Can't comment on 05 but my 03 does it, I can't imagine they would have changed it.
Quick Reply: First Gen (03-06) G35 Sedan Tips/Tricks/Facts You May Not Know
