G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V35 2003-06 (https://g35driver.com/forums/g35-sedan-v35-2003-06-15/)
-   -   Loose wire, can't find where it goes! Help! (https://g35driver.com/forums/g35-sedan-v35-2003-06/412766-loose-wire-cant-find-where-goes-help.html)
x53G35x Aug 6, 2012 10:51 AM
So took the fam to Timmies for donuts and drinks. Got home, got out and was 15 ft from the car when I noticed a loose string hanging from my bumper.
Got as far under the car as I could and noticed it was a gray wire.
Said wire has a dual port connector on the end.
The wire originates from somewhere at the bottom of my shock/strut on the passenger side. Is it the tire pressure sensor wire? Will post pics if I need to.
Help!
Edit: its on the passenger right front.....
05_SkylineSedan Aug 6, 2012 11:37 AM
1 Attachment(s)
My quick guess is "Intelligent Key Warning Buzzer - Engine Room". Front left side? Pic below from 05/06 manual. There is a gray wire involved so that's why the guess.
x53G35x Aug 6, 2012 01:16 PM
1 Attachment(s)
Attachment is the best picture I got....
Edit: There is a mount that a neck out the wire with a groove mounts to. Now to find where the wire connects....
(front passenger side...)
05_SkylineSedan Aug 7, 2012 12:51 PM
OK, not sure about that one... There shouldn't be any wires like that down in the wheel well. Is your side marker light (corner) working on that side? Maybe that wire was not properly tucked back in while the fender protector was removed at some point - like to replace headlamp components?
Just a guess...
Blue Dream Aug 8, 2012 05:11 AM
Originally Posted by iwantg35sedan (Post 6536434)
what I do is just replace the fuse one by one
Dude please quit your ridiculous posts, this has nothing to do with the topic.
AreSicks Aug 8, 2012 07:11 AM
The manual lists the side marker lamps as black with a white stripe for ground and red with a light blue stripe for power. No mention of a gray wire. Only thing I can think of that would be close to the wheel well would be the marker lamp though. Maybe the sedans are different though, my manual is for a coupe.
© 2026 MH Sub I, LLC dba Internet Brands
