Replacing driver's Ikey request button on door
The button on my door to unlock has finally given up the ghost. it was an intermittent issue for a year or so and now it just doesn't work. I can get the panel off and get to the backside. Has anyone ever replaced this? Can you get the button on it's own or is it part of a door handle assembly and must be replaced together?
I think it's probably this but hard to tell from the illustration:
http://www.infinitipartsusa.com/2006...546-123382.htm I'd also recommend testing the door's wiring harness to be sure your fault is the switch. The wires that pass through the hinge area of our doors and trunk get bent and unbent over and over again... Just a thought. |
I have the same dang problem!
Originally Posted by 05_SkylineSedan
(Post 6940735)
http://www.infinitipartsusa.com/2006...546-123382.htm I'd also recommend testing the door's wiring harness to be sure your fault is the switch. The wires that pass through the hinge area of our doors and trunk get bent and unbent over and over again... Just a thought. The FSM is very cloudy on this area. I may have to pull the door panel and just do some testing of the lock and the wiring and go from there. |
| All times are GMT -4. The time now is 05:47 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
