rack and pinion replacement after problems thread
I replace both my front break and my rack and pinion airbag light flashes on and off slip and VDC light wont turn off and the steering wheel is stiff please help thank you
Did you ever get to find the problem with the VDC off and slip light?
Originally Posted by Luisgalvan33
(Post 7011736)
He hasn't logged in for almost 3 years so I doubt you'll get an answer from him. Hopefully someone else will chime in.
On the flashing airbag light there's a reset procedure I used recently to get it to stop flashing if there's not an issue with the system. Put the key in the ignition and turn it to on but don't start the car. Wait a few seconds then turn the car off. Repeat this 3-4 times then start the car and the light should go away. We pulled the front passenger seat out to fix the power switch and the car was driven setting the airbag light off. The above fix worked perfectly. HTH |
As for the VDC off and slip light issue, I have a very slow brake fluid leak after replacing a siezed rear caliper (on a 2008 G35x) and I get these lights when the fluid level in the master cylinder reservoir gets too low. I know this sounds obvious, but on my vehicle the lights come on when the fluid level is still well within the band (well above min level mark), but go away after topping off fluid to max line. I really need to pull that wheel off and fix the leak. Hope this helps, good luck! |
