Coilover install
Ok so I’m doing my coilovers on my base g35 Sedan and the passenger side strut refuses to come out even after all bolts and nuts have been detactched. I already unbolted the upper control arm and all but the strut will not move at all. Has anybody had this issue or have an idea of what to do? |
So its unbolted from the control arm and u got the 3 nuts under the hood? Is it clear of anything holding it up? If yes...it prolly just needs a good banging to break loose. |
Originally Posted by Scorpi0
(Post 7151534)
Bang on it from the top, with a mallet or something. |
What coilovers btw? |
(Post 7151536)
Yup. I installed the same ones about a month ago. They are slightly more stiffer than factory suspension. Not by much though. |
(Post 7151541)
Originally Posted by Robert Lewis
(Post 7151542)
Nice. We’re you able to get a nice drop or what? So my advice would be to drive around for a month and let the springs settle in before u make your final height adjustment. |
I know it seems like a silly question but I feel obliged to ask anyways, you DO have the vehicle up on jack stands or a lift correct? You cannot remove the strut when the vehicle has the suspension loaded.
(Post 7151556)
