CEL after valve cover replacement and tune up
HELP!! So I recently took my car in to my mechanic to change my valve covers due to a bad leak and to also perform a tune up.Before I took my car in it had 0 cel codes at all and today I went to pick up my car it had 5 codes!! Can you guys please help me? It also has a code P1113 (NOT PICTURED)
https://cimg1.ibsrv.net/gimg/g35driv...10d6087ed.jpeg https://cimg4.ibsrv.net/gimg/g35driv...4c1538929.jpeg https://cimg8.ibsrv.net/gimg/g35driv...b92dd1433.jpeg |
Have u tried erasing or resetting the codes?
Originally Posted by Scorpi0
(Post 7164495)
Did you forget to plug in your throttlebody?
Originally Posted by scumbagsleeper
(Post 7164499)
I would have taken it back the second it came on. They caused it somehow, they need to make it right.
Yep sounds like they didn't plug stuff back in properly, maybe bent one of the pins in the wire harness.
Never accept a vehicle back in that condition. |
(Post 7164509)
Update guys so my dad took my car for me to my mechanic today(I was at work) anyways they told him that they claimed they didn’t know what could have caused the CEL light and they think what’s causing it is a wire I have around my plenum (will take pic later) but what they don’t know is that I bought the car like that and I haven’t had no cel since owning it.They then proceed to erase the codes and told my dad that if it comes back on that it could be a sensor (typical excuse) anyways I now pray that my cel light doesn’t come back on or I’m going to have to take it to get it diagnosed at a Nissan dealership.Im so frustrated right now,I cherish my car and now I feel like all my plans are being ruined.My mechanic has always been good to me and fixed all of my family members cars with no problems but no I’m thinking of calling it quits.
I believe the code is related to my air intake.Could it be possible that during the installation of my valve cover they took off my intake and throttle body and put it back on to then cause the CEL Light?? Would an ECU reset be useful at this point?
ECM reset, no, that just resets the long term fuel trim.
However the other resets like throttle body zero, idle air, ...maybe. There's also a good chance that you did randomly have a sensor die. Wait and see if the service engine light comes.back on. Here are all the resets and how to do them. https://nicoclub.com/archives/g35-35...procedure.html |
Took my car today to a Nissan dealership and they recommended me to get an idle relearn.They did it for me and now I feel like my car is running better than it was before.I will give it time to see if the light come on but fingers cross that it doesn’t 🤞
(Post 7164610)
Generally if there is an active fault it comes on after 2 or 3 key cycles.
Originally Posted by Ichiglo_
(Post 7164607)
Do an entire ECU reset. like everything. there is a website that has all of the resets you can do. check your IAT sensor make sure its plugged in and getting enough voltage.
