Help!! Won't start Won't crank over
Won't start went into store game out to car off an won't start stays in Acc an On position an the break pedal is locked in at the maximum pushing pressure an just flashes key on the dash other than that no lights iv replaced the fuze box connected to the battery an still same issue any ideas?
Flashing key means the intelligent key system (push to start) no longer recognizes your key fob. Probably just need to have a locksmith reprogram the BCM to accept your fob, but sometimes it's as easy as putting a NEW BATTERY IN THE FOB.
If the fob battery did die you can literally hold the fob on the start button while you try to start the car, the shorter range RFID chip will be picked up by the NATS antenna on the start button. Also, I would put the old IPDM back in since there probably wasn't anything wrong with it. |
(Post 7215785)
| All times are GMT -4. The time now is 08:23 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
