G35 tips you probably don't know :D
Thought it would be useful to start a thread with handy tidbits about the G that most people don't know. Some I found, most came from here :biggthumpup:
Next? :icon38: EDIT:>> Okay, decided to pile the tips into one post, will probably sticky if we keep getting good ones. No-one be offended if you don't get included in the original post, it's not really required and I may not keep up :) AesonVirus: My friend has had his 08 for 6 months now and he didn't know until I told him this past week that he has speed sensitive radio volume. You cannot lock your fob in the car if you don't have another one on your person. The car beeps and the lock won't work. (Pushing the button on the door) You'd need to use the manual key to lock your fob in the car. Also, if the fob is in the trunk and you close the lid, the car will beep and the trunk lid will pop back open. sredish: I know there's a little money / credit card clip holder or something hidden above the pass. side visor... took me a couple weeks to find that one. tg1234: You can roll the windows up while you shut the engine off. I just realized this a few weeks back. I was rolling the windows up and shut the engine off. As long as you started to roll the windows first and shut the engine off second the windows will roll up. (Note: If you open the driver or passenger door, the power will cut off) terrycs: ICC users, if it's on, be careful when following a car into a curve. You will find your car accelerating into the turn after him! IvoryPearl07G: you can lock the trunk by a deactivation button in the glovebox for valet reasons. and you can lock the glovebox with your key located in the fob. a504boi: there's a cubby for in the rearseat armrest. there is no cow level (what does this mean...?) carz: if your headlights are on auto and you shut off the car at night and not exit the car...the headlights will remain on until you 1) leave 2) shut them off manually fecurtis: If you hold the unlock button for a few seconds, all of the windows will go down. To automatically raise all windows, place the valet key in the door keyhole and hold the key in the lock position for af ew seconds. These methods do not apply to the sunroof. Robizzle: It's impossible to lock your keys inside the trunk. suby01: you cant open the trunk while your driving/moving. earth0: For G35 with NAV you can search destination by entering Phone Number no address needed. popcornten: While playing CDs, if you have other CDs in the changer you can hold the track up or down buttons on the steering wheel and it will cycle to the next CD. ultimategee27: For those who have Navi the "where am i" feature is awesome. Tells you the next street coming up...the current street you are on...and the street you just passed...it also tells you how far away you are from each. soundmike: You can choose between ICC and regular cruise control by pressing and holding the cruise control button for a couple of seconds. (Note to self, stop skimming through the manual and just read each paragraph!). silverG2007: While driving in regular D, the paddle shifters (auto sport) still work. You can upshift or downshift using the paddles. After a short while, the car will automatically go back into D mode. Basically, you don't have to be in DS to use the paddles. sameerg: Did you all know, that during dusk, there is a point of time when the sun is hitting the ICC Sensor directly. If you are using ICC at that time, it will fail. It is hard to recreate, but it has happened to me a few times. fecurtis: Since we have a keyless ignition, us AT guys don't have much of a "fool proof" fail safe for when you turn the car off without putting it in park. If you turn your car off without putting it in park, when you open the door, your car will begin to chime at you relatively rapidly to let you know that its possible that the car will roll away the second you step out of it. Ahh I'll never forget seeing my G rolling slowly down the office parking garage. To add to this, on top of chiming at you like crazy, the information center in the gauge cluster will warn you that the car is NOT in park. (sadly, I've done this too, with fortunately harmless results...) rpm&my_g35 If you simultaneously hold down the lock and unlock buttons on your I-key for a few seconds it will enable/disable your car beeps/honk when you lock it. When disabled only the lights flash as usual. DigMy35X If you press the status screen it will bring up a few different split screen options. Keep pressing it and it will cycle through a split screen with the audio information on the top with the bottom showing climate, abbreviated GPS turn directions (only if you have a route programmed) and 1 or 2 other screens. It's a lot easier to see the iPod or XM info when you do this. If you voice dial a phone number you don't have to wait for the 'lady' to repeat the phone number. Once you see it on the screen you can just press enter on the steering wheel and it will dial immediately. Sometimes I just don't have the patience for her to read back all of the numbers! Stringweave For those with Ipod sync to make your playlist shuffle press Scan until you have the setting that you may desire... Ex of some settings: repeat on shuffle off, repeat off shuffle album etc. I dont think the owners manual explains this either. InTgr8r If you get a new cell phone use the 'replace' option when pairing the phone. That way your phone book will go to the new phone. DigMy35X If you press the status button it will show a horizontal split screen. If you keep pressing the status button it will cycle through different options for the bottom of the screen. So if you are on the iPod or XM it will show the music info in more detail on the top 1/2 of the screen and then cycle through options on the bottom showing climate info and turning directions for the GPS (but you have to have a route programmed in there). JamesR913 If you hold the enter button down on the steering wheel a screen pops up that allows you to go through a few menus (one of which is information, I dont remember the rest). Just figured it out the other day. terrycs I was playing around this morning on the way to work and was wondering if the engine can be shut down in drive while in motion. Well, I pushed the button and nothing. I then thought I'd push it several times and guess what ... the engine shut down while on the move. (edit: 3 pushes are required) |
You cannot lock your fob in the car if you don't have another one on your person. The car beeps and the lock won't work. (Pushing the button on the door) You'd need to use the manual key to lock your fob in the car. Also, if the fob is in the trunk and you close the lid, the car will beep and the trunk lid will pop back open. It's all basic stuff that most of us know, but new owners may not be aware. Cool idea for a new thread! |
Aesonvirus I think you can lock your key in only one way if you lock your door with the inside bottom and shut the door. tg |
ICC users, if it's on, be careful when following a car into a curve. You will find your car accelerating into the turn after him!:eek:
tg, good tip! Note that if you open a door though, power will be cut and the windows will stop rolling up. |
One key clip is definitely different in color from the other.
I'll try to take some pics tonight and if it's noticable in the pics, I'll post them. The Silver tone is Key # 1 The Gold tone key is # 2 |
Not really gold but it is diferent then the other. First I used the silver one for almost a year and hen they had the recall I grabbed the other one. That's when I've noticed wow that looks different. Only the chain part.
tg |
and you can lock the glovebox with your key located in the fob. you can go in sideways cirlces if you punch the gas at low speed and turn the tcs off. |
Aesonvirus I think you can lock your key in only one way if you lock your door with the inside bottom and shut the door. tg The power windows/roof will operate normally for about 45 seconds after the ignition switch is pushed to the OFF position. If the driver's or front passenger's door is opened during this period of about 45 seconds, power to the windows is canceled. |
there's a cubby for a gun in the rearseat armrest.
there is no cow level |
If you have a passenger who is being unreasonable and a real toolbag, you can pull over, grab the first aid kit, and hand him or her a maxi pad that is supplied with every first aid kit.
If you hold the unlock button for a few seconds, all of the windows will go down. To automatically raise all windows, place the valet key in the door keyhole and hold the key in the lock position for af ew seconds. These methods do not apply to the sunroof. |
Originally Posted by popcornten
I've looked at both keys under all sorts of light and don't see the gold tint to either of the keys as I've seen people talk about before :(
| All times are GMT -4. The time now is 06:18 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
