Steering wheel audio control malfunction when changing radio only
#31
#33
good suggestion about getting the 08 unit. since i reset my stations, the problem has not returned. hopefully it will stay that way.
Originally Posted by st1sj
i fixed my the old fashioned way.
(1) scroll through each station. whenever a preset says this "A " instead of "A1", that means the preset is somehow missing.
(2) change the channel, save the new channel as "A1"
(3) change back to the channel before, save the old channel as "A1"
(4) repeat as necessary
that should fix it, until it pops up again.
am curious as to the cause.
#34
Ditto above. I was about to post this but I was beat to it. If your preset does not say preset A1 , A2 etc. It will cause the problem. If you want 100.7 for example press your preset to that channel then scroll through up or down through some channels then back to 100.7 and then hold the button down to reset the station and it will work again.
#35
This same thing just happened to me starting 2 days ago.
Ive noticed it is because the radio deselects the station you were currently on making the program think that it is starting at the top or bottom again.
Try cycling through very quickly while the station is still selected and it will work, but I would say that we shouldnt have to play games with the damn car to get it to do what we want it to.
#37
^Thats kinda the reason why I haven't fixed it myself. The fix seems temporary. We all paid a good amount of money for our cars, we shouldn't have to deal with workarounds just to get the radio working. Any chance I can get the dealer to replace the part for free, I'm going to take advantage of it.
#38
#39
#42
#43
on
Add another G to this thread....it happen a few weeks ago but I was too busy to check if anyone had posted on this issue. Well I took my car into the dealers last week and they told me they would order a new stereo which would take 3 to 4 days. Its been 7 days n no answer from the dealer so I decided to call them today to find out what was going on. Come to find out they know what the problem is and that they need to order a "GPS module" and the radio is not defected which doesn't make sense but we'll see. They ordered the Gps module but won't be in till next week. I'll keep you guys updated on what they do and what happens.
#45
