Guaging Interest: BlackTop Aero / RavSpec Rear V36 Sedan Diffuser
#77
http://www.fastwrx.com/karexhan.html
Those are for the WRX but they might be the same size. I havent been able to measure the Infiniti ones yet. One thing I'd be worried about is the exhaust canister/tips scarping on driveways. Mine already scrapes as it sits.
#78
I tried the WRX polyurethane extended mounts--they do indeed fit. They may or may not work. I was trying them because one limb of my borla exhaust was very close to the sway bar and I wanted to lower it a bit. Unfortunately, when you use the extended mounts, my exhaust then touched the center brace in the middle of the car. however, there is an asymmetry to my exhaust (one higher one lower) so this might not be the case for the stock exhaust or any aftermarket exhaust that has perfect fitment. I would see how much room you have over your center brace. You also have to put spacers to the mount suspending the rear of the muffler also--a bunch of washers would do the trick.
