G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V36 2007- 08 (https://g35driver.com/forums/g35-sedan-v36-2007-08-217/)
-   -   HELP!! Tire pressure light and memory seat doesn't work (https://g35driver.com/forums/g35-sedan-v36-2007-08/317449-help-tire-pressure-light-memory-seat-doesnt-work.html)
as4life Dec 6, 2009 07:35 PM
I just took apart my dash to try and install some stuff. I decided not to install it myself. When i put everything back together, I noticed the low tire pressure light is now on. Also my memory seats are not working. The driver's seat and wheel doesn't move when i open the door anymore. Any suggestions?
InTgr8r Dec 6, 2009 07:46 PM
What did you take apart exactly?
as4life Dec 6, 2009 08:43 PM
I took off the radio and whatever else i need to take off to get to the radio.
tg1234 Dec 6, 2009 09:41 PM
There are 2 conectors behind the center unit. Did you take them apart? I am not exactly sure since it has been 2 years I did take mine apart but I believe both of them goes thru the same conector. Did you check the fuse?
as4life Dec 6, 2009 10:21 PM
I didn't really cut into any wires. I believe i put everything back together. the 2 connectors are located near radio?
tg1234 Dec 6, 2009 11:00 PM
Yes just under the radio.
as4life Dec 7, 2009 10:37 AM
Does these 2 connectors will also fix the tire pressure light? I will try and fix this later on today
Gdrift Dec 7, 2009 03:39 PM
If I remember correctly, there was a thread a month where someone took apart the radio and then he ran into some problem. Can't remember what the problem was or where the thread lies but it's somewhere on here. Have a look :biggthumpup:
as4life Dec 8, 2009 07:06 PM
I couldn't find it. Also today i looked under the radio and all connections seemed good. Furthermore, I checked the fuses at the driver's side and next to the battery. Still a no go....
© 2026 MH Sub I, LLC dba Internet Brands
