Audio CD and MP3 CD won't show up album name and titles
I just copied 6 CDs using Windows Media Player latest version and iTunes 10.1.1.4.
Windows Media Player used for Audio CD - playing with Track1 thru 6(instead of actual title and album name one album tested with one CD all 4 same issue) iTunes used for CD MP3 (100 mp3 songs in each 2 CDs none them playing at all) None of them showing any album names and titles only Audio CD is working. Please help me how do I burn for this G35 format songs (audio and mp3) and software required. |
It should automatically pic up the titles of the songs and artist names. Something has to be wrong with your music or software.
Originally Posted by G3507Tech
(Post 5650547)
If you have the stock Bose, you have to press and sometimes hold the "Display" button or press it a few times. Hope that helps!
Originally Posted by dukehotty
(Post 5651735)
Your MP3 CD you created from Itunes will not play from the CD changer in the trunk. It will need to be played from the dash.
Originally Posted by mrclowny
(Post 5652505)
I guess there is no better way. Just know that the Dash CD will play both MP3's and regular CD's.. The Trunk Cd changer can only play Audio CD's.
Also, as a tip you can right click=>Properties on an MP3 file and it should contain a tab with the song's info including album name/song title. Make sure these are filled in correctly to troubleshoot them not showing up right.. |
(Post 5652546)
Also, as a tip you can right click=>Properties on an MP3 file and it should contain a tab with the song's info including album name/song title. Make sure these are filled in correctly to troubleshoot them not showing up right.. so I can load 6 discs in front and 6 discs in trunk? Thank you for helping me! |
No the in dash is only a single CD player.
No u can only load 1 cd upfront. It can be MP3 or regular though.
Originally Posted by perrdave21
(Post 5652789)
My MDX09Tech loads 6 discs in front console. Thank you for the confirmation and information. |
No 6 in trunk and one in da front. :)
(Post 5654793)
when I load from front dash my mp3 is showing all details and thins time copied using Nero Express. worked fine no issue. Thank you so much for giving me the helpful information. |
I may be wrong, but I don't think the CD changer in the trunk reads ID3 tags, it just shows disc and track numbers.
(Post 5652505)
| All times are GMT -4. The time now is 11:12 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
