G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V36 2007- 08 (https://g35driver.com/forums/g35-sedan-v36-2007-08-217/)
-   -   Random Slip light at 2,000 RPM's (https://g35driver.com/forums/g35-sedan-v36-2007-08/435205-random-slip-light-2-000-rpms.html)
Zomorg3 Dec 2, 2013 10:11 AM
Pretty much as the title states. I came back and charged by battery after about 3 weeks of sitting in my driveway (off at school brought a beater there). As I am pulling off my street I noticed that as soon as I hit about 2000 rpms, the Slip light comes on and cuts my power. This only happens in 1st gear too. No I am not hammering it, especially through my neighborhood. Actually very light on the throttle. On the main street I gave it alot more gas and same thing. Now when I turn traction control off... no slip light. As soon as I turn it back on, Slip light at first gear around the 2000-3000 rpm range. I am already doing like 15 ish at that point so I don't understand why its kicking on.
I do have aftermarket wheels on, however they have been on for about 2 years so I don't see why all of the sudden they would be creating a problem.
I looked through previous threads and all I could find was the slip light coming on with VDC due to low break fluid. My fluid isn't low and I have already checked pads and everything.
If there is a thread out there sorry to have missed it after about 40 minutes of searching lol.
But seems like this is kind of a unique issue here.
Anyone else experience this??
vqsmile Dec 3, 2013 04:56 PM
It isn't the wheels that matter; it's the overall tire diameters. What size tires are you running on the front vs. the rear. If they are already borderline for overall F -> R diameter compatibility from the start (when new), then you could experience your symptoms if either the front or rear pair wore down more than the other (over time) and exaggerated the overall diameter difference.
Zomorg3 Dec 3, 2013 05:56 PM
It was very close to one another like 0.03-4 percent difference. Before. They are only on like 6 -7 months. I am wondering if the dead battery had something to do with it because it should have died within a week. So is the computer messed up creating parasitic loss ?
Deezflip Dec 3, 2013 07:05 PM
I would check the tire pressure on all four. Temperature drop in NJ could drop it down as much as 10psi. Its enough to affect rolling diameter if you were already borderline with the tire pressure to begin with.
mishmosh Dec 3, 2013 08:01 PM
What dead battery?
I have had multiple drained batteries and really you shouldn't have issues from that. Maybe consider reset by disconnecting the battery. But just going to 2k and experiencing power loss is very disturbing. Almost like limp mode but in only one gear? Strange.
vqsmile Dec 3, 2013 08:45 PM
Well, that number (0.03%) can't be right.
Did you actually mean 0.3% - 0.4% . . . or did you mean 3% - 4% ????
Big difference.
Zomorg3 Dec 4, 2013 05:03 PM
Big difference.
sorry. I meant .3 - .4
But they aren't used full year around and the tread is still extremely fresh. I was wonder about tire pressure but even still I was like hmmm is there a limp mode? Because my car never activated that espeically when my battery was dying and the Infiniti Stealership ended up blowing my transmission because of it, and they never found out the issue. I had to....
But yea its only at that gear at that time. I didn't know if something is wrong with the computer because my battery has never died in a week before without using it. Though... would the cold weather be a contributing part to this? I do have an upgraded interstate battery because we all know the stock battery in our cars is a POS.
Polishthrust Dec 4, 2013 05:11 PM
Do you have a camber kit with shims installed?
Zomorg3 Dec 4, 2013 07:36 PM
Nope, stock camber, springs and height
Zomorg3 Dec 7, 2013 11:36 PM
Just checked all the air in the tires, all are good pressure and I am still having the problem.
Mustang5L5 Dec 8, 2013 10:54 AM
Let's assume for a second that the light flashes because the car thinks it's seeing a slip condition. Only way for that to happen is if a wheel slips. The input for that is a wheel sensor giving a reading that the wheel is in fact slipping.
It may be possible the issue lies in one of the sensors. Either debris in the speed sensor ring (they are magnetic and rely on magnetic field to get a reading) or a failing sensor due to moisture. Metal on the rings could rust while the car was sitting.
Might be a good idea to inspect and clean the ABS wheel sensors and check for damage or loose debris
Zomorg3 Dec 12, 2013 06:03 PM
Update:
So I completely drained the car of electricity to try and reset everything. Wala! It worked no more random slip light. I am wondering if when the car drained when I hadn't driven it for the week if it messed something up in the computer.
Plus the tune I reflashed back on seems to actually be responding better thank god lol.
I originally through that, however, there were too many variables like why the car was completely dead after not driving it for a few day when I would go a couple weeks before not driving it and the battery was still strong.
Haven't found any parasitic loss from the car when it was off, so possibly it didn't turn all the way off last time maybe and was stuck on ACC power....? But in the event the sensors were dirty, it would have had me slipping through the first two gears and it would have continued to slip if I kept it in first while going higher in the RPM. Plus I would have had sporadic instances of this before too. My parents QX56 have had some weird things happen to it, like computer issues or dash issues, which I found out when completely draining the car of electricity from all the circuits (Not the battery), it would usually fix all issue, except the ABS randomly kicking on which we found out not only the QX's had the issue, but Armadas and pathfinders too with Nissan/Infiniti knowing about it but not covering it under warrenty (including drivetrain to 60,000 miles since its not "considered" drive train) :52:
Rodney Allen Jan 6, 2014 11:12 AM
I had the exact same thing happen it was the level of break fluid. Tapped it off, never happened again. BTW where did you get hose sick running lights. I. Have a 07 g35 and those are the best I have seen.
Zomorg3 Jan 6, 2014 03:12 PM
Yea it wasn't the normal VDC light for the brake fluid cause I had that too and I checked but...*Update*...hasn't come back since so since it aint broke, im not touching it.
However had to replace power steering pump :(
What model g35? Do you know if you have the sport bumper or not?
Rodney Allen Jan 6, 2014 04:16 PM
1 Attachment(s)
Sedan not the sport bumper. That's why I liked your setup. It looks like the chrome reaches the sides of the fake vents. I'm putting my baby in the shop to get the bumper retouched.
Would love to have the shop put them in.
© 2026 MH Sub I, LLC dba Internet Brands
