Following. I have a 2008 Infiniti EX35 adn my car does the same thing. Wanting to know more about this PCV, how to change it and the part number.
Originally Posted by dabshere
(Post 7119924)
I've been having this exact same issue with my 2008 g35x. I've took it to mechanics and they couldn't find an issue. It shuts off all the time at low speeds and especially when I'm slowly turning. Have you had the same issues after doing what you did? Thanks |
Originally Posted by Krystal Melinda
(Post 7129623)
With the vehicle parked, engine running, turn the steering wheel. Does engine rpm drop substantially?
Sounds like the power steering pressure switch is crapping out. Take it to Nissan for a diagnostic if the battery passes a load bank test. The PSPS allows the ECU to increase idle as the steering wheel is turned (which is a substantial load on the motor). |
