07 g35s 5at just brought it
Hi I just purchased a 07 g35s with 110000 I have no maintaince records and I want to go ahead and change/replace whatever parts that are needed at this mileage. The car drives good suspension feels a little soft and seems a little sluggish. What do you guys suggest I have done? And I'm thinking about letting hill garage possibly work on it but I can do basic stuff I'm more familiar working on Gm ls cars
No records at all? Even on a Carfax or dealer running the VIN? Odd.
Start with the basics; ALL fluids All filters Belts Brakes Plugs Bushings For the preventative side of the house; PCV valves Valve cover/gaskets CAM position sensors Coolant hoses TB/MAF cleaning Battery - test it first |
Originally Posted by VenomGT9
(Post 7025729)
Start with the basics; ALL fluids All filters Belts Brakes Plugs Bushings For the preventative side of the house; PCV valves Valve cover/gaskets CAM position sensors Coolant hoses TB/MAF cleaning Battery - test it first Thank you |
