Blown engine advice needed
My father overheated the engine in my 2008 g35x and I want to swap the engine out. I was going to buy a used engine and have a mechanic install it. Is there anything special about doing this that I should be aware of and is alright to buy a used engine from an fwd g instead of an awd thanks for your time.
Originally Posted by Gikosta
(Post 7091814)
Telcoman |
^ +1 for a new car. and there is no FWD G35
(Post 7091814)
You'll need an engine from an AWD car since the oil pan is different to accommodate the front drive shaft. You can swap over the relevant parts from your engine if you got a RWD engine, but that makes things a little more complex than just a drop and swap.
