Mileage won't increase.
Old 05-13-2018, 12:21 PM
Khan839's Avatar
Hiya.
i have a 2008 g35x. The mileage is stuck at 118k kms. The trip A and B also stys at zero and do not increase.
i have tried the guage cluster diagnostic mode but to no avail.
I really need the trip mileage to check fuel economy and service intervals.
Old 05-13-2018, 02:17 PM
cleric670's Avatar
BANNED!!!
Received 2,456 Likes on 2,150 Posts
Coupe 6MT Premium RAS
Does everything else work?
Old 05-13-2018, 04:09 PM
Khan839's Avatar
Yes all the gauges work as normal. Even the digital display works like it should.
Old 05-13-2018, 06:08 PM
cleric670's Avatar
BANNED!!!
Probably a failed instrument cluster.
Old 05-16-2018, 12:37 AM
dookie's Avatar
Originally Posted by Khan839
Hiya.
do you have a navigation bypass switch? if so, it's entirely possible that you are wired up incorrectly and effectively disabling the mileage detection. I did this by accident once by miswiring the bypass switch I won't say how, but i'm just sayin...
Old 05-16-2018, 04:04 AM
Scorpi0's Avatar
Drive the car for hundreds of thousands of miles. Then resell it as low miles
Old 05-17-2018, 05:24 AM
Khan839's Avatar
navigation bypass? You mean the bypassing the factory system to play videos when the car is moving as opposed to factory system which only works with the parking brake engaged.
the car didn't came with a reversing camera from factory so the previous owner installed one. He didn't used a relay wired the camera directly into the AV port so now i have to press the aux button while reversing to bring the camera view. I dont know if the camera wiring has anything to do with it.
Old 05-17-2018, 05:25 AM
Khan839's Avatar
If nothing works out then this is my last resort. 😂
Old 05-17-2018, 06:26 AM
Scorpi0's Avatar
If its an aftermaket radio, there is a way to wire it up so the camera comes on automatically when shifting into reverse.
Old 05-17-2018, 06:47 AM
Khan839's Avatar
its the stock one without the navigation system.
Old 05-18-2018, 04:33 AM
Scorpi0's Avatar
Im not sure how the stock stereo works, but I bet theres a signal wire somewhere which tells it its in reverse.
Maybe someone can confirm this?
G35Bandit
Forced Induction
05-27-2011 10:55 AM
Infinite1
03-14-2010 09:26 PM
marty315
03-10-2008 02:56 PM
Derp
01-20-2007 11:27 AM
Skyline_G35
07-05-2006 04:16 PM
Quick Reply: Mileage won't increase.
