G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V36 2007- 08 (https://g35driver.com/forums/g35-sedan-v36-2007-08-217/)
-   -   G35X Clicking won't start (https://g35driver.com/forums/g35-sedan-v36-2007-08/464894-g35x-clicking-wont-start.html)
Sean Hopkins Oct 8, 2018 04:13 PM
I know there are a bunch of starting threads on the forum but don't quite see end answer to my problem. I thought my battery was bad and jumped it (with a lot of effort) had it checked and was told it wass ok little low needed some charge. I hadn't driven the car in around 2 weeks went to start it seemed like dead battery again. Bought a new battery still wouldn't start. It would just click. I tried to jump even the new battery and engine seems to slightly turn with revving the jump car but wouldn't start. From what I read on here, seemed like it would be the starter. Mechanic replaced it and checked everything still won't start. They are telling me the Engine is bad which I don't see much of common occurrence on here. Mechanic said engine is hard to turn. Could something be binding off the drive belt not letting it spin? Alternator AC compressor? I checked oil was fine no metal in it. I was worried coolant seemed low in overflow but was totally full when open radiator. Any insight would be much appreciated. I find it hard to believe engine is bad with 90k miles on it. Thanks for the help.
cleric670 Oct 8, 2018 07:28 PM
Disconnect the drive belts, pull all the spark plugs, put it in neutral and turn the motor by hand with a socket in the crank pulley nut. It's pretty obvious when you have a spun bearing because it turns REALLY hard.
© 2026 MH Sub I, LLC dba Internet Brands
