Please please help ....caliper mess
So while changing my front brake pads....my neice got in the car and hit the brakes ....now the piston is on the rotor, and i can push it back to remove the caliper but it won't go all the way back....I don't know what to do
PIC https://docs.google.com/file/d/0B4DY...dZWkhMOUk/edit |
Your pic isn't working. Are you using a "C" clamp?
pics are working again
I was able to push it back some but loosing the rotor.....I can get a flat head screwdriver in between the piston and rotor, but non of the pistons won't go back anymore all the pistons are all stuck at the same height |
The piston are probably hitting the seals since it doesn't look like they going back in straight best thing you can do is if you can take out the caliper you can try to push back in straight or take out the piston and lube it up then try to push back in hopefully the seals didn't get messed up
Originally Posted by Glex25
(Post 6652070)
https://docs.google.com/open?id=0B4DYQuLjb-WqU0xGUm9mSDd6Q1U I do see the psition move up if i slightly tap on the brakes.and go back just alittle bit. |
