G37 V36 Sedan 2009 + Discussion about the G37 Sedan
P0011
Old 11-26-2018, 01:29 PM
Nemises1979's Avatar
g37 base
P0011
Well I got the dreaded P0011. What I have done so far
- Changed Oil ( didn't work)
- Removed and cleaned and reinstalled both VVT control solenoids (didn't work)
- Bench checked VVT selenoids (hooked up to 12 v source and verified they were clicking)
- Changed gallery gaskets reset ECU (didn't work)
Before I go replacing more parts; are there any other tests I can try? My next option I would guess are replacing the VVT selenoids and cam position sensors. I was sure it was the gallery gasket, now 3 full days of work later my car is still in limp mode and I feel like I am just guessing. I would guess next would be to replace VVT solenoids as I heard that sometimes they will pass the bench test but have week springs inside. I also read that it could be intake timing sprockets needing to be replaced. I sure hope not because I would HATE to have to take the motor apart again.
Old 11-26-2018, 02:50 PM
telcoman's Avatar
Have you ever considered following the troubleshooting steps in the FSM?
https://www.nicoclub.com/FSM/G37/Sedan/2009/EC.pdf
Telcoman
R1Chick
Drivetrain
01-27-2016 11:55 PM
Blue Dream
13
03-16-2015 05:31 AM
jwglennie
03-01-2012 01:17 AM
Ronjon17
11-12-2010 01:25 PM
MM_G3520
01-26-2009 08:10 AM
Quick Reply: P0011
