G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   General Media Share (https://g35driver.com/forums/general-media-share-240/)
-   -   Metal noise coming from rear right wheel (https://g35driver.com/forums/general-media-share/450643-metal-noise-coming-rear-right-wheel.html)
atk08 07-30-2015 03:12 PM
Hi! i have a 2006 g35x and i recently started hearing a metalllic noise coming from the rear right wheel (sounds like a loose bolt or something like that) i only hear this noise when going over a bump at a slow speed...now here is where it gets tricky..there is nothing loose on that wheel or the suspension (which i actually replaced thinking it was the problem causing this noise) i have seen my mechanic 3 times since this problem showed up and he also hears it yet there is nothing lose..tie rods are fine as well as the bearings which i also had replaced not too long ago..also switched the bushings on the suspension and no change there either...it is really annoying loll...i have heard that sway bar end links can cause this type of sound even if they show no signs of damage when visually inspected...wondering if any other g owners have had this problem and if replacing the end links might solve it?!
© 2019 MH Sub I, LLC dba Internet Brands
