AC won't stay cold
I'm trying to trouble shoot what is causing the problem.
04 coupe I put a AC pressure tester on, and no matter how hot it is outside, it stays betweenn 35-45psi. I used the dye to see if I could find a leak....no leak detected. If the ambient temp is below 75, the AC is cold. but anythinng 80+ it blows cool. The compressor comes on without a problem. I have not found any signs of any leaks, not even in the cabin. I have recharched the system and i have no change. one thing I noticed, that i am not sure if its normal or not, is that the low side of the pipes gets really cold, but the high side actually stays warm. any suggestions will be appreciated |
I bet its your heater box
mine wont turn off!...LOL
Originally Posted by digital1986
(Post 4533360)
Care to elaborate more |
| All times are GMT -4. The time now is 02:43 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
