G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   General Tech Questions (https://g35driver.com/forums/general-tech-questions-189/)
-   -   Can't Open Hood (https://g35driver.com/forums/general-tech-questions/336064-cant-open-hood.html)
ivan.do May 4, 2010 09:05 PM
Can't Open Hood
I have a 2003 Infiniti G35 coupe, but recently haven't been able to open the hood. The hood switch underneath the steering wheel doesn't seem to open the hood when I pull it. Has anyone experienced this problem, or have any advice to fix it? Is there a manually hood switch on this model infiniti?
codeflux May 4, 2010 09:09 PM
nope. you'll need to use a coat hanger or something to get it opened. your cable likely snapped.
ivan.do May 4, 2010 09:19 PM
should I use the coat hanger and go in from the front of the car?
UCIMAplaya2 May 5, 2010 12:25 PM
happened to me once. I thought the cable had snapped but as it turns out, the clip that holds it into the knee bolster had popped out after a recent install that required it to be pulled down. So when I was pulling on it, it wasn't able to pull the cable the required length. I figured it out when i gabbed the cable itself with pliers and it popped right open. Took the knee bolster down and looked at the clip and saw it wasnt even in place.
© 2026 MH Sub I, LLC dba Internet Brands
