Horn Doesn't Work
The other night, my neighbor came to my door, and said that my alarm kept going off. I went outside, and nothing was happening, except my horn would not work.
Today, I checked the fuse, and it was in fact blown. I replaced it with a spare 15A fuse, started the car and pressed the horn. WHen I did that, it was very faint for about 2 presses, then it stopped working again. I checked the fuse again, and that fuse blew as well. Anyone expierence this before, or know what the problem might be, as why the fuses keep blowing? Thanks |
Blown
More than likely your horn shorted out due to the "alarm kept going off".
Disclaimer: do at your own risk. If you can take it out, see if hooking directly to a battery makes it work. Connect it for not more than half a second. If it doesn't work, you need a new horn. |
Yeah, I will have to try that. Thanks
| All times are GMT -4. The time now is 10:00 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
