How to access blower motor relay behind fuse box?
How do I access the relays behind the fuse box? I took out some of the paneling along the kickplate as well as the cover that reveals all the fuses and plugs. However, how do I remove the fuse box so I can get to the relays? I am stumped. I can find any resources in threads on videos on youtube.
Is there a screw, or just all tabs? Those tabs are a god awful. 2003 infiniti g35 sedan. |
you have to remove the battery cover and the left plastic guard by the windshield wiper, its only held on by little clips that a flathead screwdriver can easily remove. After that you will see a larger fuse box which will be the IPDM....just remove the cover and voila!
Originally Posted by terrywhite84
(Post 6767309)
I found my answer in this post: https://g35driver.com/forums/5631244-post22.html There are two 10mm screws that you have to remove. Easiest to remove with a ratchet. |
