G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   General Tech Questions (https://g35driver.com/forums/general-tech-questions-189/)
-   -   2006 g35 coupe 6mt won't start up (https://g35driver.com/forums/general-tech-questions/446052-2006-g35-coupe-6mt-wont-start-up.html)
FroesWorldd Dec 20, 2014 11:19 PM
I was trying to adjust my clutch for my comfort, I took the clutch switch apart from the behind the peddle. It mad contact with another piece of metal and sparked, I gave it no interest so I carried on. After I was finished, i held the clutch down normally to start the engine and it didn't do anything. I've checked the starter and ignition relay as well as all the fuses. The car was working perfectly before I did this, what could it be? the key turns but it doesn't crank up.
Justice06RR Dec 22, 2014 09:35 PM
I believe there is a sensor on the clutch pedal that tells the car if the clutch is depressed when it is started. Since you had a spark on the clutch switch (name ?) that is probably what happend--you messed up that safety feature and now its permanently on and won't allow your car to be started.
I would consult with a service manual if you have one, if not have the car towed to the dealer (if you can afford that route). Good luck.
jtmobsta Dec 23, 2014 06:31 PM
Sounds to me like there's got to be a blown fuse in the box.
DroidDonACR Dec 24, 2014 11:57 PM
x2 Check the fuse or the sensor for thr clutch
© 2026 MH Sub I, LLC dba Internet Brands
