G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   General Tech Questions (https://g35driver.com/forums/general-tech-questions-189/)
-   -   Oil cooler leak (https://g35driver.com/forums/general-tech-questions/449892-oil-cooler-leak.html)
soiler 06-22-2015 09:13 AM
Oil cooler leak
I was told by the local repair shop which I trust that the small oil leak I have is coming from the oil cooler. The estimated repair cost is $ 712.00. Seems like a lot but I'm figuring it's not an easy job. It's a 2004 G35X with 141K miles. Just wondering if this is something that needs to be done.
coffeysm 06-23-2015 12:56 AM
It's a dollar < 10 gasket and 15 minute job that can be done at your next oil change. Even if you had to replace the cooler it's still extremely simple.
Unscrew filter bolt deep well 22MM if I remember right, take out old gasket, put new one in, and retighten it.
If your oil cooler is hosed you might need to drain some coolant, but procedure is same except you disconnect the two coolant lines going into it.
rsingerG35 06-23-2015 04:13 PM
Don't forget to apply a light coat of new oil to the gasket and tighten to 36 ft lbs.
soiler 06-23-2015 04:34 PM
Oil cooler leak
Thank you...I need to find out why the quote to do this job was so ridiculous.
saywat? 06-24-2015 08:31 PM
ill do it for u for $600
soiler 06-24-2015 08:41 PM
Nice of you..figured someone would make me an offer...lol.
Hate to question a shop I trust on estimates..but need to ask them what's up so I can get it fixed.
yosip1115 06-25-2015 09:20 AM
Oil cooler could have cracked too, you don't know if it is that or if they are over-charging for a gasket. It happens from over-tightening oil filters time after time.
