(Slip light VDC light Off) keeps coming on
Guys I need your expertise.
Love my G35x but these lights are driving me crazy. Heads up on my regular driving conditions: I live in Connecticut and my work route is under construction grooves and bumps. It seems as my Slip and VDC Off light is coming on at least once on my way to work (highway). And yes when this initially started my SES light came on and continues to stay on even after I turn off car park for hours start car up and SES light is on but my Slip light and VDC is off: Until it happens again this happening frequently. Seems too sensitive 😒 |
Had the same.
Check brake fluid level. Low brake fluid means you should check for worn out brakes. |
Mry, did you ever find the solution? I’m also from CT with this exact problem |
Originally Posted by djjojo860
(Post 7144753)
Mry, did you ever find the solution? I’m also from CT with this exact problem It was the left or right bank sensor.:) |
Originally Posted by Mry
(Post 7144778)
Yes I did!! Thanks for asking :hello:
MRY, when you say bank sensor, do you mean 02 Sensor?
(Post 7144807)
but I can call the Infiniti dealer and ask if you'd like.. It was a headache for something so simple to repair |
No need to apologize, I honestly appreciate your help. This issue has been driving me insane. Especially when the brakes engage on their own. Whatever information you can gather, would definitely be appreciated. Thank you. |
Probably a wheel sensor, O2 sensor has nothing whatsoever to do with the VDC system.
Thank you for your response, I’m going to look into that.
(Post 7144812)
It was a bad caliper wasnt always releasing right away ...hope this also helps Felt like I was towing something.. |
I'll go into my glovebox tomorrow I should have the service papers in there..and I'll post with pictures:smile021:
Addendum:.. ok the problem was rear drum wouldn't always release.. had complete rear left and right down with emergency brake approximately 875.00 |
This was the problem when my car had trouble stalling out going down the highway :conf17: and hard starting.
(Post 7144815)
One more thing my car was having random problem felt as if the brakes were on...
Worn front suspension can also cause these lights (SLIP/VDC) especially if your steering wheel isn't centered while going straight.
Originally Posted by Scottwax
(Post 7144904)
'Check Engine Light' which is equivalent of:smile027: |
