G35 fuel pump
Why G35 coupe fuel pump does not fit to sedan? What is the issue with it, basically same car.
For the same reason the coupe has dual exhausts and the sedan does not. Different configurations.
G35 fuel pump
Originally Posted by DeafBringer
(Post 7034643)
Originally Posted by QX1
(Post 7034719)
But if you take the OEM coupe fuel pump off from the frame and put it on sedan would it work? The pump I asume is the same and dimensions also?
G35 fuel pump
(Post 7034760)
I would assume no because of different locations. Look at the part numbers and cross reference between the coupe and sedan. If they're different, then they are not interchangeable.
