New G35X 05
New G35X 05
is this normal for a new bearing to do thiis is the bottom section that sits on the hub
this is what happens when you simply lift up
please help bought two of these, they both do the same thing one is mounted on the hub and if you could see him the picture when you lift up the Hub kind of pops out a little bit. the one that's not mounted you can lift it up with your fingers, I went to a local store and look at their top brand and it did the same we just a little bit of resistance
Bearings, especially non sealed, will have play/seperate on the bench when no press is applied, which usually comes from the hub/spindle nut. This is nothing out of the norm. BTW this is the new members check in thread. Please refer to the correct tech thread for such questions, and welcome! Also, if you must post pics in this thread let's see some pics of the car!
Received 2,456 Likes
on
Coupe 6MT Premium RAS
RXM
Archived Sales
09-02-2009 04:38 PM
PeterUbers
06-23-2009 08:50 AM
