Hazzard Flasher
Hi,
My first post here! I have a 2008 G35 coupe and I need to know where the hazard flasher is located. My hazard lights will not stop flashing, I removed a fuse block from the IPDM under the hood to keep the outside lights from flashing bit the interior signals on the dash keep going. I am looking to replace the relay once I find it and I ordered a new center dash with new hazard switch. Please help with location and or pic! Deal said I need to pub a new $800 IPDM or I can get one off ebay, but I should just be able to replace a flasher... |
If you completely disassemble the IPDM you should be able to de-solder and solder back on a new relay. Have you tested the button to make sure it's not just broken internally in the closed position?
(Post 7159003)
I have a new console array on the way, the one that controls the display and settings and it has the hazard button in it. That is my first step because I figured the button could be broken in the on position. Is the IDPM the long thin box in front of the battery or the larger one to the left of it? |
It's the one full of fuses and relays, on the.coupe there's only one thing. Not sure about sedan, I assumed it was the same.
