What can you tell me about my alignment?
So I kinda eyeballed my toe adjustment on my rear wheels a few hundred miles ago since they looked like they had some excessive toe in. I adjusted them for more toe out. I did an inspection of the tires recently to see how theyre wearing and this is what I found. The edges of the tread look like theyre "folding" up. What do you guys think? Are these an indicator of too much toe out?
Shot of the rear side of the tire, outer edge. Looks like the trailing edges of the tread are lifted up.
Same
Rear of the tire again
Here's a shot from the front side of the tire
Same
Received 2,456 Likes
on
Coupe 6MT Premium RAS
Take a tape measure and as accurately as possible measure the inside measurements of the wheel-to-wheel at the front and rear of the wheel.
I used one of this style of tool (*see link) for MANY years to make adjustments to street and track cars, if you screw a couple sheets of plywood together and drive the vehicle on top of it then use a crossline laser like a Spectra LT20 you can draw a REALLY accurate picture of the current alignment down onto the plywood (put down masking tape to write on). Then just jack the vehicle up and make small adjustments, lower it, roll back a couple feet and forward a couple feet to settle everything then re-measure.
It wasn't until I made friends with the guys down at a local alignment shop that does a lot of custom work for modified vehicles that I started ever paying for my alignment
https://www.ebay.com/i/132300114192?chn=ps
A wheel indicator like this as well as a camber level and you can definitely make your own adjustments at home, just need a very flat and level surface to do it on.
EDIT: I didn't have a real camber gauge until recently, I typically just used a 360 degree magnetic protractor and stuck it to the wheel gauge or a piece of very straight wood cut to fit the edges of the wheel.
Scorpi0 (05-03-2019)
on
Cool. Yeah I guess it is feathering. I can tell it was an indicator that my toe is off. Just couldn't tell if its in or out. I did the camber myself and it was a pain in the asś trying to create a level surface using pieces of tiles under the wheels. I took my sweet time to get everything perfect and when I drove over the tiles they just all shattered with the weight of the car on em lolll. I finally managed to find a more even surface and get my camber in spec. I sure as hell dont wanna go thru that again though.
I found a reputable alignment shop close to me that specializes in lowered and custom cars. I talked to the dude over the phone and he seems to know his stuff. I'll be takin the car to him soon to get it straightened out.
Originally Posted by Scorpi0
Well I got my alignment done and it was all over the place! He couldnt dial out my rear camber because he said my toe was limiting it from going any further. He said he can dial out about another 1° if I install my aftermarket toe bolts though.
Heres the sheet.
Heres the sheet.
on
G35 Coupe
Toe in factors
I’m also struggling to hold spec toe in. I’ve replaced ball joints, LCA bushings, but not compression rod bushings (yet). Dealer is trying to tell me strut coils are sagging/worn, which is causing toe to continuously change. I’ve replaced struts, but not coils. I was told by suspension shop to only replace struts at 140K, coils are fine.
Do coils on this vehicle lose spring rate and height ? Also, if so, do sagging coils affect toe in ?
Thanks for insight,
Cliff
2004 G35 coupe
160K
Thanks for insight,
Cliff
2004 G35 coupe
160K
Sabretooth
05-23-2015 12:08 PM
Albis
03-20-2005 04:03 AM
