g35 radiator leaking ?
Old Oct 24, 2020 | 03:01 PM
ninjabong's Avatar
2005 g35 automatic 148k miles heres a video of it leaking
figure it's definitely the radiator I could try a new cap but i dont think thats going to fix it what do you guys think?
also in the manual it says
. Disconnect A/T fluid cooler hoses. (A/T models) ● Install blind plug to avoid leakage of A/T fluid.
where do i find the right size blind plug?
Old Oct 24, 2020 | 09:25 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I suspect you have a failed radiator, the top crimped on section of a plastic/aluminum radiator is a weak point that's usually the first part to fail.
HOWEVER, you should rent a pressure tester to verify.
Old Oct 24, 2020 | 09:56 PM
ninjabong's Avatar
thanks for the reply yea I figured it's got to be my radiator since the neck of the radiator right under the cap is completely dry. Its just the seam leaking and there is no where else that the leak could be coming from. Both the radiator hoses are below the seam obviously. So I ordered a denso radiator. do you know about the a/t fluid that they are talking about in the manual? I don't think it's actually the a/t fluid is it?
Old Oct 24, 2020 | 09:57 PM
cleric670's Avatar
BANNED!!!
Looks like coolant in your video. Pressure test can confirm this.
Old Jul 13, 2023 | 05:00 PM
nbsmanny's Avatar
2010 g37 sedan
My 2010 g37 sedan is leaking drops from the front where the radiator is on the bottom but coming out through where the fans are what could that be a bad radiator??
Old Jul 14, 2023 | 09:55 AM
Urbanengineer's Avatar
rent an auto parts store pressure tester and see where it leaks from.
Old Jul 15, 2023 | 12:12 PM
cleric670's Avatar
BANNED!!!
And use a good flashlight and inspection mirror.
dimentio1
Mar 11, 2015 12:12 AM
LelandKing
Dec 5, 2012 03:20 PM
G35xChicago
Nov 5, 2012 10:15 AM
