Doing 30k Service myself..whats needed
I have 3 manuals with 3 different lists of items to be changed. I can't get a definate answer anywhere... What do I need to buy and or service on my 04.5 6mt coupe...
Should be in the service manual that came with the car.
Check Belts
Check Plugs Clean the MAF sensor Air Filter/Clean aftermarket filter (if dirty) Check In-Cab filter I would do a coolant change Tranny/Dif change Oil Change/Filter Check Tires, Tire pressure, torque lug nuts not necessarly the nissan 30k but just some things to do if ur bored |
The Premium Maintenance list in the service manual is what the dealership is suppose to do.
Can you pls post how much you end up spending ($ for parts and time). It would be nice to see the price difference compared to what the dealership charges. My local Infiniti dealer charges $499. |
Thanks...
Yea I will post what I do and how much everything costs.. The reason I am asking is because the service manual that came with the car is different than; the dealership, the online infiniti service webpage and the nissan dealer. I was just wondering what guys have replaced that did their 30k service.. My local dealership wants 600. I will itemize everything I do. Here is what I have so far. Change Oil/Filter. Change Air Filter. Change Micro Filter. Change and Flush Coolant. Change Rear Diff Fluid. Ill check everything I can.. Anything I am missing? |
include what i've listed.. if your AT they might include a tranny flush too..
Infiniti shop times to $ are something like $200 for breaks (a pair) $200 for flushes (yep careful) and rest is less then $50.. =\ when u go ask for a discount.. iono if it is true at all infiniti dealers but managers and advisors are able to give 10% |
How do u prove if you are doing the service urself? for warranty purposes? from a shop, at least you have a receipt.
+1.. see I'm curious to know if you don't have major maintanence schedule such as 30k, 60k, etc... how this will effect infiniti warranty.
Everyone asks this and there's no firm answer. A dealer will tell you to ensure your warrenty coverage you should have them done, but thats really more so they can get your service money. At the end of the day it depends on how fussy the particular dealer is and what the problem is that you need repaired under warranty. If the type of problem you are having looks like could be a result of bad maintenance such as not changing the oil or a bad A/C because the microfilter is clogged, they can deny you coverage if they can prove that your lack of maintenance caused the damage. The prove goes both ways. They may ask for prove that you did the maintenance, but really they have to prove you did not do it to deny you coverage. I think if you ask around the most common denials of service are done because of aftermarket parts and not service checks... The 30k checkup is mostly filters and inspections; the tranny and coolant change is deemed "only if necessary" after inspections in the service manual. |
Your receipt is one way to prove that you at least purchased the parts that needed to be repaired.
Maybe you should take and save pics of the old parts you removed and the new parts you installed? Better safe than sorry... |
Don't think the dealer cares if you used genuine Nissan parts if you're doing your own maintainance. What if you did something wrong, didn't tighten bolt, etc...? Dealer can find some stupid excuse to void your warranty.
I believe this has been tried in the courts before (imagine that) and the receipt of purchasing the requiste parts was good enough to prove the recommended work has been done. That was reasonable proof the work had been done as who would know enough to pruchase all those things, then not do the work to install them. The funny thing is, my Jeep has 146,000 miles on it, and the only things I've ever changed are the coolant, oil, and transmission fluid (once). It has the original brake fluid (holy crap!), differential, transfer case, all that jazz and she's still a trooper. I would in no way recommend that as a course of action though.
take a look at this thread:
https://g35driver.com/forums/showthr...ghlight=charge it provides a hefty list and some other information such as avs007's post regarding warranty denial. Good luck! Scott |
