- Importing
- Crankshaft position sensor connector wiring
- Miss My G37
- No Start ‘05 G35 ECM questions
- Scratching my head
- Official Gas price thread
- Serpentine Belt is not moving and it’s loose
- 2008 G35 x sport blown head gasket ?
- G35 to G37 dash conversion
- Cam sensor bank 1….
- G35 Straight pipe Res or no res
- Engine Swap
- Seat covers
- gallery gasket repair shops around nyc ??
- Car not starting - Electrical mayhem
- G35 VDC and Slip, Brakes locking up.
- RXEV35
- My first G…
- Water in trunk
- Car won't start
- Water leaking behind glovebox after engine replacement
- A little help- interior part identification/fixing
- 350GT-8 CVT Sedan - Wiring Diagram
- Trying to figure this out.. what should I do what’s best to do??
- What to do to my g!
- HELP. Cylinder 3 not firing!!
- Skyline Plates available
- Test pipes, advice
- To Anybody On the Fence- Uprev tuning
- Replacement Headlight Assembly for 07 G35 sedan
- How much to spend on G35?
- Bent Pulley Bracket?
- Self diagnostics mode
- Help!!!
- Know any Auto shops?
- Random misfire code (P0300) and doesn’t stay running
- Tips or advice?
- Possible rod knock ? What is this noise
- Weird noise from engine bay
- Spark plugs/coil problem
- Roof rack and Blizzak winter tires for sale
- Power windows issue
- G35 blown engine.
- A/F goes to 18 when taking foot off gas even in higher Rpms
- How do you get rid of pee smell in the carpet
- Does upgrading to the 75mm throttle body require a retune?
- Need serious advice please!
- Boosting the g35
- Whole sunroof flew off my car??
- Rpm jumps with at check on while driving as if i went to neutral
- Crank No start.
- Crank but won't start
- 05 rev up - Change in Exhaust tone when downshifting/decelerating.. pls help🤯
- Need Good G35 Mechanic in San Jose CA
- Issue. PO1273 bank one circuit lean
- Need advice for MORE POWER!
- You Know What Really Grinds My Gears
- Heeelp
- G35 shifter rattle/transmission
- Cluster doesn’t show when in drive and tiptronic doesn’t work
- G35 keeps stalling and idling horrible
- Custom Headlights
- Where to purchase Crawford HF Cats??
- Vq35DE Rev up swap to a Vq35HR
- Exhaust / Noise
- Angry now
- Should I swap my 2003 6 speed coupe for a 350z hr
- Big question
- G35 won’t do donuts anymore
- Worst experience with any company....
- Cold air intake and exhaust improvements
- G35 Automatic to Manual Conversion HELP!
- A - Pillar
- G35 Coupe with GTR R35 nismo spoiler fit on a G?
- Athens Blue Option
- Gas pedal response
- G35
- One-owner 6,500 mile G35 6MT coupe on BaT
- Quick release steering wheel set up
- 2012 G37 Seat Belt pretensioner - tightening under moderate braking
- How do I take Driver side seat motor out? I've loosened the 3 screws already. 03 g35
- Need information about 02 sensors
- Getting no spark please help
- Key light on dash
- The G is DEAD!
- My gear indicator went blank
- 21 Year old NJ Infiniti Diiver arrested for DWI
- What are brembo g35 front caliper mounting bolt thread size ?
- Does anyone know where I can find this part?!
- Can a blown engine damage the transmission and catylic converter?
- First POV Drive!
- G35 turbo Blown engine + engine replacement.
- Might actually cry
- How a Powerful Nissan Insider Tore Apart Carlos Ghosn’s Legacy
- Ricers!!!!
- 07-08 g35x exhaust!!
- G35 in need of help
- Engine swap from modified to stock?
- new be
- UPDATE! on HELP!!!!!!!!
