PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Injen Intake is now Installed!! w00t
  2. Dynojet vs Mustang Dyno
  3. Oxygen Sensor Splice
  4. Is It Worth It?
  5. Horse power increase on 2005 stick verse auto
  6. Best Road to Accelleration?
  7. Need Actual Link to get MotorDyne Plenum Spacer
  8. Body Repair (cosmetic) suggestions in Los Angeles?
  9. Does the G35 have an OEM oil cooler?
  10. Place that sells OEM Parts
  11. ECU Chip
  12. ECU tuning option
  13. New to the G35
  14. Will a 350Z engine cover fit a G35 with the Crawford plenum?
  15. I Need Help With A Dent!!!
  16. G on 20s
  17. Slight whistle during hard accelaration
  18. Basic Mod List
  19. Type of Modifications That Wont Void Warranty
  20. Types of Modifications You Can Do To The G That Won't Void The Warranty
  21. Circle Earth HKS: Lost in the hieroglyphics
  22. fair price for used coupe mid pipe?
  23. What does a pop charger do?
  24. Buddy Club Ground Wire Stablizer Kit?
  25. When to do ECU?
  26. Calling ALL DATALOGGERS...
  27. engine shuts off
  28. Cats install goes awry
  29. How is the filter setup with the Vortech?
  30. fuel light comes on when i still have 6 gallons left
  31. Half-A** Spacer
  32. Where to Buy Crush Washer for Oil Drain?
  33. You know the old Question? Injen & water?
  34. Emerg/Hand Brake Adjustment
  35. ECU Reflashing/remapping tool
  36. Crawford Performance Cast Plenum Question?
  37. The Best Remote Starter
  38. Stillen Engine Dampener Brace
  39. horrible noise on startup
  40. Just got my New 05 G35 Coupe 6MT !
  41. Problems with Crawford....
  42. stock cat diameter??
  43. compass malfunction
  44. do you need to tune car after mods?
  45. Anybody install performance ignition wires?
  46. what happened to StrictlyZ??
  47. Where do you get Amsoil?
  48. 0-60 time on '05 stock G35 with sport suspension package
  49. Motor oil question.
  50. Tire Light
  51. Viper Remote Start
  52. First service
  53. G35 w/ Procharger + Borla Exhaust
  54. Motordyne vs. AAM Plenum Spacers
  55. 2004.5 Technosquare Dyno!!!!!!!!
  56. Choosing an Air Intake
  57. Does my parking brake need adjustment?
  58. Christmas Gift Installed! RE Short Shifter!
  59. Need Help!!! New Plenum And An Overheating Car!
  60. turbo kit on ebay
  61. Interesting Intake Aluminum Specs
  62. Dipping below 6 seconds
  63. which intake?
  64. Wanted!!! 350z Intake Tube
  65. Nismo Cold Air Intake...
  66. plenum spacer question
  67. intake combo
  68. Stillen Headers
  69. Ricer Is getting Even Better with Some Spoon Calipers
  70. Service Engine Soon Light
  71. Is the Z-tube worth getting?
  72. Have a 05 coupe need help pickin out sum aftermarket parts
  73. Help Me Find A Diy Please
  74. Greddy Twin Turbo Kit
  75. NGK Iridiun IX Cooler Plugs
  76. G35c vs M3
  77. Rwd G35x ????
  78. Laser jammer placement
  79. Who has the best price on the JWT clutch/flywheel combo?
  80. Can you Paint the Stock Plenum???
  81. just bought a spacer!!! hahahahahha
  82. OEM '04 350Z Touring springs?
  83. Best mod for low end improvement?
  84. painting center console
  85. New Cast Crawford Plenum
  86. Does Anyone Have A Schematic For O2 Sensor???
  87. Grounding Kits and " Z tube"
  88. Motordyne Plenum Spacer Vs Crawford V5
  89. Injen CAI install HELP!
  90. Easy V1 hardwire/hardmount
  91. UT-R Power RAM Charger with heat shield Prototype
  92. Mods
  93. Split Second Products
  94. have you checked your plugs?
  95. Wiring Harness Help!!!!
  96. prelim dyno results with Hydrazine's plenum spacer
  97. Need help
  98. ProFlow TB...
  99. Mapping Intake Plenum Mods (Getting Dynoed)
  100. Camshafts
