17" Coupe Wheels on a Sedan
Old Oct 24, 2005 | 02:17 PM
andrewsm's Avatar
Does anyone know if the 17" coupe wheels will fit the sedan? I heard there is a difference w/ the larger 18 and 19's from the coupe, but I don't know if this is the case for the 17" package.
F: 17x7.5 +30 offset
R: 17x8.0 +33 offset
Thanks,
Mike
Old Oct 24, 2005 | 02:18 PM
MikeyMike's Avatar
Rollin On Dubz
The coupe 18's fit on the sedan, so i don't see why the coupe 17's wouldn't either.
But I wouldn't bother with that.
Old Oct 24, 2005 | 02:25 PM
andrewsm's Avatar
I should have clarified, I have a sedan w/ 18's (05 6MT). Somone I know has a set of 17" 350Z takeoffs which have the same offset as the 17" G coupe (according to him). I'm thinking about getting some blizzak's and using those 350Z 17's if they will fit.
I don't want 18"s for the winter since they are significantly more expensive for the tires and wider is worse in the snow.
Thanks
Old Oct 24, 2005 | 02:55 PM
MikeyMike's Avatar
Rollin On Dubz
Yes, they will fit. The bolt pattern for the Z and G's is the same. And the offsets and widths should be ok on the sedan too.
Old Oct 24, 2005 | 03:08 PM
andrewsm's Avatar
Thanks. At what point is there a problem? I saw from other posts on the site that the sedan has a +45 offset.
Old Oct 24, 2005 | 03:20 PM
MikeyMike's Avatar
Rollin On Dubz
I think some sedan guys have had rubbing issues when they are lowered, but if you're running stock suspension it should be ok. I mean I am not a rim expert and I am always asking the other guys who are more rim savvy their opinions...but from what I've gather...these should fit fine.
Brodys_GCoupe
Nov 7, 2015 08:06 PM
teamghost
Jul 28, 2015 04:52 PM
tiguy99
Jul 26, 2015 01:39 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
