G35X Exhaust same as RWD from axle back?
I'm wondering if the 05/06 G35X exhaust is interchangeable with the RWD exhaust from the axle back? Specifically, I'm looking at an HKS axle-back exhaust, and I can't find out if it will fit the AWD G35X (without changing the midpipes for the time being).
Could I just throw in a midpipe from a coupe at a later time, or does it require modification? How much will that run me, if it does? Thanks in advance! |
The HKS will fit fine on the x. however, since you got an 05/06 you need the extra bracket for the HKS rear section. If you got an 05+ the coupe middy won't benefit you at all, if not none. Just get the HKS rear section and you will be more than happy
G35freak86, what is the extra bracket that you need?
Oops, I thought I posted it, I guess I closed the window without hitting post :P. You can get it from Riverside Infiniti (I can't get a direct link to work, but go there, go to sedan aftermarket accessories, then go to exhausts, then rear section only, and you'll find the bracket).
What trioptimum said. the 05/06 need a different bracket to mount it up. The 03/04's use the bracket already on the car
Well, Riverside tells me they don't know for sure if it will fit without modifying the car and/or exhaust. I'm ordering it anyway (found a guy on eBay who said I could return it for a 10% restocking fee if I made sure not to scratch it up) and I'll post back in a week or two with my results, for future reference.
Is anybody 100% certain it will fit without modification? That would be nice. I can install the exhaust myself, but I can't bend pipe, and I bet that costs a good $100 or so :D. Thanks again for the input g35freak86! You were very helpful in my decision. |
No problem man. Glad I could help. I'm pretty sure it should just bolt right up. I don't see why it would be a problem
For future reference, the HKS exhuast bolted right on with the adapter bracket from Riverside Infiniti. First place told me it wouldn't fit (Firestone), but the second place (Munro) told me it fit perfectly.
It sounds pretty good - not quite there yet though, the pop charger is too high pitched, whistle like. Would adding a z-tube to the pop charger, or the coupe mid-pipe, change the sound at all? |
Adding a z tube will DEF change the sound. It will give it a great growl. I would highly suggest getting one to pair it up with your Pop Charger.
A coupe middy on the 05/06 sedan's won't do much, if not anything. The coupe middys only change sound for the 03/04's. |
stillen and oem z zube is prett much the same thing. I would go with the oem z though. It'll give it a nicer deeper tone
Nice bro, I just ordered hks muffler for my 05 RWD sedan and the brackets as well. I have a coupe midpipe, it does make a difference but not as big as in the 03/04 sedans, but I def hear the deeper drone. If your going for a nicer sound, don't go z-tube, unless you get it with the jwt charger. Otherwise a nice intake like injen will cure the appetite for hearing your engine wide open throttle. If you get a coupe midpipe locally, don't hesitate to throw it on, you won't regret a slightly deeper exhaust...
trioptimum, which hks bolted right up? the HKS Sport (the one which THMotorsports has a group buy for)?
yes that one. That's the only HKS for the sedan that is out there
interesting... i was just told it wouldn't fit
