JWT and Z-Tube figures
Hey All,
Can someone please let me know what the reasonable RWHP is with a JWT Popcharger and Z-Tube installed? Also further down the line I'll be replacing these items with a SC, so I would like to know with that in mind, what type of exhaust would one recommend? Thanks! Ox 2003 DG 6MT Go that way, really fast. If something gets in your way, turn. |
Re: JWT and Z-Tube figures
nice quote from better off dead LOL
2003.5 DP 5AT Sedan (E-thing but Nav) 14.2 @ 97.18 Z-Tube K&N Drop In & Airbox Mod 10 Wire Hyper-Ground Crawford Plenum (V4) UR Crank Pulley Polk EX-3500 Tweeters/Shock Sensor/H-Liner |
Good catch SixFive. Most people don't get it. I guess that's a sign of either our age or good taste in movies.
Our central florida dyno day results showed Ztube/Popcharger combo to have a solid 7rwhp and 7torque gain on 5ATs and about 5rwhp and 5torque gain on 6MTs. These are both all the way through the curve, not just peak.
'03 G35 Coupe | Black on Black | Performance 20% tint | Clear Corners | Ztube & Popcharger http://www.cardomain.com/id/dabomb3 |
Well since I have the data from the CF Dyno Day in front of me might as well re-post the info... the AVERAGE GAINS across the board seem to be a little lower than what dabomb sited...
5AT stock / redline = 227.6rwhp & 216.7 rwtq 5AT Z-Tube, P/C / redline = 231.6rwhp & 220.5rwtq 6MT stock / redline = 229.7rwhp & 222.6rwtq 6MT Z-Tube, P/C / redline = 229.2rwhp & 226.7rwtq If I remember right the average gains across the rpm range were about 5rwhp and about 5 ft-lb rwtq. FYI, this is the mod to do for sound, not performance. 301-bhp!!! ...and growing! |
Thanks Neff, i was too lazy to go get the actual values.
I remember that the peak comparison is misleading as through the curve the gain is a couple more (especially on 6MT) but yes this is a sound mod unless u have a aftermarket plenum that can take advantage of the added airflow....search for "Central Florida Dyno Day Results" and read Neff's great writeup and spreadsheet of the results. '03 G35 Coupe | Black on Black | Performance 20% tint | Clear Corners | Ztube & Popcharger http://www.cardomain.com/id/dabomb3 |
Now would you say that the 4rwtq is gained by the z-tube or the pop charger? I'm still debating between the jw pop charger and a k&n drop in filter. Then one day I will wake up and say I want an Injen, so indecisive. Does the bumper have to be completely removed to install the Injen?
-= 2004 G35 Coupe/6MT/DG/4pc Aero/Sirius =- |
Read the dyno day info and you'll know the answer to this question. People dynoed with the z-tube and P/C, the Z-Tube and P/C with no heat shield, the Z-Tube and stock air box, etc...
Originally Posted by Oxanar
Hey All,
Can someone please let me know what the reasonable RWHP is with a JWT Popcharger and Z-Tube installed? Also further down the line I'll be replacing these items with a SC, so I would like to know with that in mind, what type of exhaust would one recommend? Thanks! Ox 2003 DG 6MT Go that way, really fast. If something gets in your way, turn. as for exhaust for n/a you will need a 2.5 inch but if you plan on FI go with 3 inch Fast Intentions is a very good exhaust... search it... |
Talk about an OLD thread. :thewave:
Damn i didn’t realize lol... i guess i have two pointless post
LOL Way to work on the post count Beebo! 2004? Really?
lol, its probably alot funnier when you can't see where the threads have been deleted
O RLY, you taking over Msedanman's spot as top poster soon or what? He's held that title for as long as I've been a member.
