Advanced Resonance Tuning (ART Pipes)
Old 02-10-2010, 10:33 PM
Hydrazine's Avatar
Originally Posted by Silencer_0
Lol jayk! Add the MD sways to that too .
Any discount if i get these and provide sound clips + dyno tests?
Dyno tests would be what gains these pipes would have over my F.I. HFC's though...
Of course.
DISCOUNT FOR DYNOS
  #47
Old 02-10-2010, 10:35 PM
Dsskyline's Avatar
Tony, what is the dia of these pipes 2, 2 1/2 or 3? I might pick up a set to compare against my RTPS along with your cat module.
Do you have pics of these installed?
  #48
Old 02-10-2010, 10:40 PM
Hydrazine's Avatar
Originally Posted by cthrulies
Hydrazine, I'm a little overwhelmed & amazed considering all combinations available with MD exhausts.
Before I the ART pipes, I settled on the Shockwave TDX V2, since drone was no longer an issue in 5AT's.
But now, I'm thinking ART pipes, Shockwave (V1) with XYZ CAT.
My question is how would these setups compare in sound & performance?
I do realize I'll have to wait for dynos & sound clips but more explanation from you would be appreciated.
Thanks
The TDX will have an edge but they are pretty close for NA. If you plan to go FI, then get the TDX for sure.
  #49
Silencer_0's Avatar
Originally Posted by Hydrazine
Of course.
Excellent . So these ART pipes will further reduce droning, make better power at lower rpm's than regular tp's, and might even quiet down the exhaust a bit? PM me how much it would cost please .
  #50
Old 02-10-2010, 10:41 PM
TofuProductions's Avatar
Nice. I'd be interested.
I'm just a tad bit worried on the clearance for install, not to mention since no flex pipe is offered, how the longevity of the pipes will last.
They do look great though.
  #51
Old 02-10-2010, 10:42 PM
Hydrazine's Avatar
They have a 2.25" inlet and a 2.5" outlet. No pics installed.
RTPS?
  #52
Old 02-11-2010, 12:19 AM
Tollboothwilley's Avatar
1) Yes.
2) No, but if you want extra bungs its easy enough for a local shop to add.
They show a large peak relative to test pipes because test pipes lose a lot at that point.
The dyno plots I like to use are A minus B plots. This method of plotting shows the deltas in VASTLY greater detail and clarity.
The traditional dyno plot may work for showing absolute peak values but they leave the viewer pulling out a ruler and pencil to figure out the deltas at various RPM's. And mod performance is important over the whole curve, not just at the power peaks.
I agree that area under the curve is what we're looking for but most people get caught up in "peak." Just glad that someone takes the time and patience.
PM a price & discount for independent dynos please
  #53
Old 02-11-2010, 10:38 AM
Sen's Avatar
Sen
Sen is offline
So the beauty in these is that it really improves low end power (torque) which would be lost with normal pipes.
  #54
Old 02-11-2010, 10:51 AM
Dsskyline's Avatar
RTPS?
resonated test pipes. I have the labree 2.5 test pipes.
  #55
Old 02-13-2010, 09:37 PM
in production correct? availability?
  #56
Old 02-13-2010, 09:40 PM
alfhasg35's Avatar
it's on their website.. oh.. i just checked the website and ...
ur webpage says " I N F I N I T Y "
just wanted to let you guys know Tony..
Alf
  #57
Old 02-13-2010, 10:59 PM
PTownG's Avatar
isn't that the same basic concept the hks exhaust employs on their mufflers?
  #58
Old 02-14-2010, 12:01 AM
gabe3d's Avatar
  #59
Old 02-14-2010, 12:15 AM
I didnt realize that those extensions were for the O2 sensors til you posted up those pics. O2 sensors will still get a good reading there?
Tony, with the remote location like that would having a wideband bung welded in affect performance at all?
  #60
Old 02-14-2010, 12:20 AM
gabe3d's Avatar
Tony, forgot to ask you this in the post above. Why is there some steel wool like material inside of the O2 bung?
Quick Reply: Advanced Resonance Tuning (ART Pipes)
