Megan V2 TP...is your check engine light on?
I just got mine installed a few days ago and today the check engine light came on....
I thought it wasn't supposed to come on with these :52: Who has the Megan V2 Test Pipes? Is your check engine light on? |
yep the light came on but when I got car tuned they turned it off
I have the service engine soon light on :S i just installed it 2 days ago...HOW DO I GET RID OF IT!!! do i needto take it to the dealer?!?!
Did any of you get the non foulers? im about to order some v2's and just wondering if that would do the trick. i heard it does.
Without getting complicated, the REVUP motors are harder to fool when it comes to adding test pipes than non REVUP's.
The Megan V2's have non foulers built-in, but it is very short. An additional 90 degree non foulers may be needed. Statik sells them for around $35 but it isn't guaranteed to always work. http://www.meganracing.com/uploadima...IV-O2EXTV2.jpg |
i have the non-foulers and my G isnt rev-up.....hmmm anyone else have an imput or solution to get the light off??? could it possibly be that the sensors burned??
Any1 can help please?????!?
Originally Posted by adamls2
(Post 5479767)
Originally Posted by Jairen
(Post 5485968)
What type of "non-foulers" do you have? Have you tried L-shaped non foulers? Have you pulled the code to see what it actually is?
A little off topic but.. did you have any noticeable gains with the test pipes? Also how much louder did it make your exhaust? Any rasp?
Yes there is a proven gain with test pipes. The OEM cats and y-pipe are all restrictive.
Test pipes or HFC are almost a must if you decide to get a tune in the future and want full potential of a tune. Yes the exhaust will be louder. Rasp is going to depend on the rest of the exhaust. |
Originally Posted by 626Gthirtyfive
(Post 5500074)
i just added some nonfoulers from oreilleys and drilled out the center til the sensor fit through......1 on each side....engine light never came on from that point on.
i just got the v2 test pipes for my 05 coupe and i dont want to have my cel light on after i get them installed. So the_coupe when you say you drilled yours out what do you mean? so the o2 sensor would go all the way through the oreilly non foulers? and are these the ones you got?
http://www.oreillyauto.com/site/c/de...eyword=foulers |
Originally Posted by RelliKg35
(Post 5503158)
