G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Intake & Exhaust (https://g35driver.com/forums/intake-exhaust-23/)
-   -   Ok so CAI's don't add power... but how about after a tune? (https://g35driver.com/forums/intake-exhaust/371960-ok-so-cais-dont-add-power-but-how-about-after-tune.html)
asneakyrocker Mar 29, 2011 02:11 PM
Can anyone comment on whether a CAI will give more power vs. stock box or SRI after a tune?
I am asking because I am thinking of buying a CAI but from searching I see that it doesn't add anything vs. stock but I have other mods such as 1/2' spacer, popcharger, test pipes, & exhaust... as well as a tune...
Do you think it will add some wHP if I switch to a CAI and retune?
asneakyrocker Mar 29, 2011 02:12 PM
maybe this is the wrong section to post?
herrschaft Mar 29, 2011 02:21 PM
Right section.
The CAI will still be susceptible to heat soak, so I wouldn't use it.
ratm68 Mar 29, 2011 03:04 PM
i think you're fine with the pop-charger, marginal difference between intakes IMO.
lcysimon Mar 29, 2011 05:52 PM
You will probably gain hp only after a tune.
After market CAI tends to make the car run rich without tunes.
You can read the intake myth sticky.
© 2026 MH Sub I, LLC dba Internet Brands
