G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Intake & Exhaust (https://g35driver.com/forums/intake-exhaust-23/)
-   -   Most restrictive part of a G's exhaust system? (https://g35driver.com/forums/intake-exhaust/80455-most-restrictive-part-gs-exhaust-system.html)
Boostnboobs Jan 4, 2006 06:32 PM
I am considering running test pipes with a good y-pipe and that is it! Will this be beneficial? I might add some headers in there.....just not sure.
Sukairain Jan 4, 2006 06:43 PM
IIRC:
Restriction on stock exhaust system
Cat > Y-Pipe > Mid-pipe back > Header
I think you will notice a decent improvement replacing the cat and y-pipe. Be sure to hear the test pipes first though. You will get significant rasp with test pipes.
2Evolved Jan 4, 2006 07:12 PM
i figured most of all cars the most restrictive part of the exhaust was the catylic converters
Gsedan35 Jan 4, 2006 08:07 PM
Remember, most aftermarket Y-pipes aren't really ment to be used with a oem mid pipe no matter what they might say. A 80mm output into a 65mm oem mid pipe creates a 1/4" abrupt wall in the flow path. Tanabe's Y-pipe has a 70mm output, maybe some carefull grinding on the oem mid pipe inlet can smooth things a bit, just a thought to those that won't replace their oem mid pipe with a aftermarket one.
sun55amg Jan 4, 2006 09:57 PM
Cats, then y-pipe or headers, then cat-back exhaust.....
SI_G35Coupe Jan 5, 2006 12:33 AM
ditto on that... i was running a Fujitsubo Y-pipe (with header and cats) which is 86mm outlet into the ~60mm stock midpipe.... big restriction in my flow, and you should have seen the ring of nastiness on the midpipe flange when i finally got the Legalis-R installed.
if i had to do my entire setup again, i'd to high flow cats, y-pipe, and exhaust. the headers were a major PITA and $$$ to install
GT-Ron Jan 5, 2006 10:55 AM
If you're going to stick with the OEM mid- or rear-section, at least make use of a reducer cone to avoid the abrupt wall/transition others are talkinga bout.
© 2026 MH Sub I, LLC dba Internet Brands
