Emergency light and Cigarettes light don't work....
Old Apr 28, 2010 | 08:07 PM
Brian-g35's Avatar
I tried switching out the fuse but that didn't work, what else can be the problem?
Old Apr 29, 2010 | 11:40 AM
Brian-g35's Avatar
Anybody?
Old Apr 29, 2010 | 11:55 AM
0MGHI2U's Avatar
Hmm.. Did you check the fuse under the hood behind the battery? If not check and then try to disconnect the negative battery for 5 mins and then install and try to see if that fixes the issue.. I had that fix a similar issue before
Old Apr 29, 2010 | 02:03 PM
IowaJim's Avatar
What do you mean the cigarette light? Do you mean the power plug in the dash?
Old Apr 29, 2010 | 03:26 PM
Brian-g35's Avatar
Yes...ashtray location and emergency light don't work..
Old Apr 29, 2010 | 05:26 PM
IowaJim's Avatar
My cigarette lighter plug is also out. I'm too lazy to figure out why. But this intrigues me. I don't know about the emergency light. You meant he emergency flashers? If so, that ought to be on its own circuit. Anyway, I'll check mine. What year do G35 do you have?
tiguy99
Mar 1, 2016 11:42 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
beevanhuynh
Jul 14, 2015 09:06 AM
