Easy way to change Clearance Lights
i installed them myself...its very very easy to install..first i thought it would be alot of thingy needed to do..but took me 30mins for the first side and 15min for the 2nd...most the time is spended on taking off the heavy wheels..
i just took off all clips screws on the front wheel weel and just pull down the front wheel well hard,cause the back wheel well is holding it from under.
when i did this install i check,try to learn how to get into the fog lights or hids..but didn't really figure it out...have no idea..i'm going to change the fog and hids next, can someone PM me the steps how to change the fog lights and change the hid lights? thx!
to do it with out removing the wheel...
u need a car jack!
jack it up...u will have more then enough space to do the install!
i did my fog in less then 15 mins each side
there is about 2 screws and 5 clips..i remember
then pull the liner down hard don't worry those stuff won't brake on u!
u need a car jack!
there is still one more screw that u cant see in the picture, BTW the two bottom clips in the first picture, u dont have to remover cause u can just peel it back with them on
Also all u have to do is jack up the car, i didnt even turn the wheel and there was still plenty of room to work w/
