Entry/Exit Function Not Working
I have a 2005 Infiniti G35 Sedan. My problem is I disconnected the battery to do a repair, new valve covers. When I put it back on now the Entry/Exit Function does not work. I did the following reset procedure.
I can get the memory to work. I put the seat, steering in my position and use the Set and Button 1 to memorize. Then I move seat, steering to a different position. Then when I push the button 1 it goes back to the memory. But when I shut off the car and open the door the seat and steering wheel will not open up to exiting position they just sit there. Reset Procedue: "Initializing entry/exit function The entry/exit function can be activated or cancelled by pushing and holding the SET switch for more than 10 seconds while the ignition switch is in the LOCK position. The indicator light will blink once when the function is cancelled, and the indicator light will blink twice when the function is activated. If the battery cable is disconnected, or if the fuse opens, the entry/exit function will be cancelled. In such a case, after connecting the battery or replacing with a new fuse, open and close the driver's door more than two times while the ignition switch is in the LOCK position. The entry/exit function will be activated." |
